Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
UPDATE: Driving around today... the car's sterring wheels shimmy's left to right a little...
Old 07-11-2005, 03:43 PM
S6 4RiNGS's Avatar
Default UPDATE: Driving around today... the car's sterring wheels shimmy's left to right a little...
when drving down the street and then when i hit the brakes, the steering wheel does it a little more. Is it possible that new pads on warped rotors could be causing this? Also can old pads conform to a warped rotor somewhat to make it not shake. because before it didn't shake really at all. Well that i could notice anyways. i will prolly tomorrow take it all apart and redo the install. but some insight on my thoughts here would be helpful?
Old 07-11-2005, 03:57 PM
spiralsmurf's Avatar
Default dude you should never install new pads on warped rotors. you should get new rotors
Don't try and turn the old ones either.
Old 07-11-2005, 04:00 PM
S6 4RiNGS's Avatar
Default well thats just it... i didn't even know they were warped until now!!!! but will the new pads be
shot if i change out the rotors by the end of the week? oh and i know that rule, btw.
Old 07-11-2005, 04:05 PM
S6 4RiNGS's Avatar
Also, are the new pads junk now?
Old 07-11-2005, 04:25 PM
The Librarian's Avatar
Default Your new pads are tighter to the rotor right now than the old pads were, so the warped...
rotor is bumping into the pads as the wheel goes around (Wumba wumba wumba) causing you to feel some shimmy in the steering wheel. You needed new rotors. If you do nothing, it will probably get better because the space between the pads and the rotors will increase a bit. However this decreases your effective braking response time and you STILL will have warped rotors which you will feel pulsing underfoot when you brake.
Change the rotors now while you only need to do them and not the pads (again) too.
Dave F.
Old 07-11-2005, 04:56 PM
i would say yes. you can try the new pads on the next set of rotors, but chances are they're toast
Old 07-11-2005, 05:08 PM
S6 4RiNGS's Avatar
how can new pads used less than 150 miles be toast? Can y ou explain?? i don't know this logic!
Old 07-11-2005, 05:09 PM
S6 4RiNGS's Avatar
So... your saying change rotors asap, leave the new pads i just put in?
Old 07-11-2005, 05:13 PM
Turbo_Anarchy's Avatar
They are fine, just get some rotors.
Old 07-11-2005, 05:20 PM
S6 4RiNGS's Avatar
Okie thanks.
Quick Reply: UPDATE: Driving around today... the car's sterring wheels shimmy's left to right a little...
