What do I need to convert an aux-in signal to match the stock cd-in signal?
I tapped into the cd-in signal at my gamma head unit and installed an aux-in jack for mp3s. I did the same on my old C4 and it works well, but the sound quality isn't close to the same as the cd.
The cd-in reads 20k ohms and the aux-in reads 3.3k ohms. Do I need some sort of in-line amplifier?
Tapped into the two wires marked "line-in", one is green/black, other is white. Ran those to a swtich which I connected the cd and aux inputs to...So yes, the cd changer wires are disconnected when the switch is flipped.
Is there a third wire (ground?) coming from the CD player?
It's been a long time since I did this so I can't give you specific instructions. I used a DPDT relay to switch the two signals and left the grounds connected all the time.
The Chad (VaultPSU)
12-18-2006 08:52 PM
Joker1626
9
11-06-2005 06:13 PM
Ulilbastrd
11-02-2004 07:06 AM
FasTTr
07-22-2002 08:18 AM
