What's 443907388 for?
Under the ABS section:
"ABS - System Description : MY91-93
Longitudinal Accelerometer - It is unclear if all early ABS systems on the S2 have this component. More research is needed as I suspect it may have been deleted before the introduction of the OBD equipped ABS controller became standard equipment. The purpose of the accelerometer switch is to close an electrical contact in the event of sudden G-force increase in a forward direction - such as when braking heavily. Notated as F113 on the schematic.
ABS - System Description : MY94-95 Revisions
At some point in time, Audi decided that the risk of someone blaming them for causing an accident by allowing the driver to disable a safety feature such as ABS was too much of a risk to continue with. For the 1994 model year, a number of revisions were made to the ABS on the 80/90 series. The most significant change was the deletion of the ABS cancel switch. In relation to this change, there was no need for the combination relay. Finally the longitudional accelerometer switch was also deleted. "<ul><li><a href="http://www.s2central.net/main_frame.html">Click here and then on the ABS link.</a></li></ul>
S4 Slowpoke
10-10-2006 06:10 PM
h8r
05-24-2005 09:21 AM
