What's the flow rate on RS2 injectors? I know some people were using 37lb/hr as a subsitute, but
it's not exactly the same. Racetronix has a new 32lb/hr injector. <A HREF="http://www.racetronix.com/621020.html">Click</A>. Is that the same flow rate as the RS2 injectors? They're $100 cheaper each than the RS2 injectors, so they would be a good option to get and run with the 370 software. Thoughts?
Thanks,
Mike
Thanks,
Mike
<ul><li><a href="http://www.audifans.com/marketplace/show.php?table=pm_audifans_Parts&id=1962">http ://www.audifans.com/marketplace/show.php?table=pm_audifans_Parts&id=1962</a</li></ul>
Stock are 280cc @ 3.0 bar. The stock fuel pressure regulator is rated at 4.0 bar and the RS2 at 3.8 bar.
Hap , talkin dahkine fool in Evahboost
The "370" software is already a little lean in some cases, with RS2 injectors, now if you run 32lb. injectors, it's gonna be a matter of hours before it all blows up. Get 37s, why be limited in future tuneability and get 32s?
HTH,
mihnea
HTH,
mihnea
Mihnea, curious... is there a software package that I can order from you that works with the 37lb/hr injectors, but is also pretty cheap because you don't have to come out and tune my car? Granted, I won't be doing this anytime soon... so I've got time to save some money, but I'm still curious. I'm gonna be asking these wicked annoying questions for at least another year.
