Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
whats a true rs2 setup?
Old 03-02-2007, 07:36 AM
greenaudiurs4's Avatar
Default whats a true rs2 setup?
-rs2 turbo $1615cnd
-rs2 exhaust manifold $786cnd <(wagner tuning)(034motorsport $$$???)
-rs2 injectors (37# lbs/hr delphi D3165BA $205cnd for all 5) racetronix.com
-ecu chip $500-$900us range
OPTIONAL
-rs2 maf $497cnd or "de screened oem maf" or 928? or 944 turbo?
-rs2 cam $1083cnd "optional"
edit>>no need to change coolant/oil lines when used in AAN S4.
ps I will post where and cheapest prices I have found..if you know of somewhere better lmk I will edit it
Old 03-02-2007, 07:39 AM
itsav8's Avatar
Cam.
Old 03-02-2007, 07:45 AM
Default Re: Cam.
ooo cool didnt know thanks
Old 03-02-2007, 07:49 AM
germantoy's Avatar
Default they're magically delicious (can you tell we have an exhaust leak prob at work)
whole workplacee is high
Old 03-02-2007, 08:07 AM
Tech Guru
4Driver4's Avatar
Very few people go as far as the cam. Some don't bother with the MAF. Lines are the same.
Old 03-02-2007, 08:21 AM
UrS4boy's Avatar
Default You don't need oil or coolant lines (KKK RS2 turbo uses stock line). Almost nobody...
does the RS2 cam (not much benefit). I think you can find RS2 turbos for less money than that. If you go with RS2 clone injectors or Lucas/Delphi injectors, you can bring down your costs considerably. You don't need the RS2 MAF, tuners have software that uses the stock MAF. Software is anywhere from $500 to $900 (US).
YG Hotmail as well.
Old 03-02-2007, 08:26 AM
Mr.FRU-T-Pants's Avatar
Default I think testing bears out that RS2<7A in terms of efficiency and power.
Of course, I wouldn't run the 7A ex. cam alone with all the supposed overlap, but I *would* run the RS2 alone. I think Rich has done the testing via his buddy in Seattle. I know they were missing one cam set, but I can't for the life of me remember which one among stock, 7A, and RS2.
Old 03-02-2007, 08:32 AM
MiniMan's Avatar
Has an RS2 cam ----&gt;
Old 03-02-2007, 08:36 AM
quattro20v's Avatar
Default Your exhaust manifold is a good price, but the turbo is expensive.
As other have said, most don't use the cam.
Personally, I'd use the true RS2 injectors. The MAF is debatable.
Old 03-02-2007, 08:44 AM
ThetaTau87's Avatar
Default RS2 MAF vs. stock MAF??? Any documented gains?
What are the differences? Diameter, screens, etc...
Is the RS2 MAF the same part # as the 968 MAF or does Porsche have a different part #?
Quick Reply: whats a true rs2 setup?
