where does one buy replacement vacuum lines that go to the IM...
I tested all my hoses, no leaks. The hose that goes from the swivel T to the IM ripped up when i took it off. Its hard as a rock... So i need to probably replace the entire apparatus, i have a source for a T connector, where have you guys bought hose from? and does anyone know what size hose it is? thanks guys.
Also, with the vacuum line disconnected my car was still having idle issues, and hesitation from idle to start.
So i have ruled out vacuum leak, coil, pos, spark plugs. I guess that leaves MAF... ECU? man what a stupid problem, everything i check is always OK, now i have no boost to go along with it.
some new hose onto it. Im upset that testing it is causing me to deal with a new problem now, but that hose was pretty messed up to start with.
thanks for the reply.
for this job as my t fitting leaks at the swivel and the hose and clamps are too big.
still got the leak![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
let me know where you source usable parts
still got the leak
selfproclaimedv8buff
01-03-2005 02:23 PM
nosrednug
04-12-2004 10:25 AM
RS41AB
01-23-2004 04:41 AM
