why is climate display in this format and how do i change it to normal?
<center><img src="http://pictureposter.audiworld.com/107366/s593645724_28762_3207.jpg"></center><p>
Press and hold the recirculation button. Then press the temperature up ("+") button to switch between degrees Celsius & Fahrenheit on the Climate Control Temperature and Instrument Panel Outside Temperature displays.
Reference: Unlocking the Secrets within the Climate Control Panel
in the AudiWorld Tech info (see URL).
Try Searching once.<ul><li><a href="https://www.audiworld.com/tech/int.html">https://www.audiworld.com/tech/int.html</a</li></ul>
audiKP
07-02-2007 06:00 AM
