Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
which wire on coil pack used for tach? need help with remote starter install
Old 11-14-2006, 12:43 PM
New Member
Autobahnjs's Avatar
Default which wire on coil pack used for tach? need help with remote starter install
i have it all wired up.. search says black wire in wiring loom for coil?
the car cranks but will not stay on i need signal to tell alarm the car is on
Old 11-14-2006, 12:51 PM
UrS4boy's Avatar
Default Not in the coil pack (AFAIK). The answer is in the attached links.
<center><img src="http://pictureposter.audiworld.com/15624/enginespeedignitiontimingsensors.jpg"></center><p>
<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/116211.phtml">Link to ECU pin-out - looks like Pin 40</a></li></ul>
Old 11-14-2006, 01:16 PM
New Member
Autobahnjs's Avatar
Default Re: Not in the coil pack (AFAIK). The answer is in the attached links.
perfect thanks.... looks like G28 pin 40 should work i wonder if its easier to tap into the g28? if not ecu i will go with
Old 11-14-2006, 01:23 PM
UrS4boy's Avatar
G28 will likely be easier to get at if you haven't accessed your ECU before.
Old 11-14-2006, 03:04 PM
New Member
Autobahnjs's Avatar
Default Re: G28 will likely be easier to get at if you haven't accessed your ECU before.
ya the ecu has never been touched,, will try the g28 first thanks
Old 11-15-2006, 10:57 AM
New Member
Autobahnjs's Avatar
i followed the senor to the coil pack loom... its a 3 wire conector i tried the black wire nothing..i tried the brown and it works but then the car will shut off..not sure what it can be
Rocket SLC
9
03-05-2021 09:09 PM
zola1
Inline-5 Discussion
11-11-2008 03:48 AM
banana s4
10-24-2008 10:49 PM
spiralsmurf
12-10-2005 01:48 PM
daphne
10-28-2000 08:12 PM
Quick Reply: which wire on coil pack used for tach? need help with remote starter install
