X-plug and PS pump questions
As far as I know under X plug there is a small
piston which will wear with age and start to
leak as under it there is high pressure and then
changing Xplug o-ring stop leakage for some time but
sooner or later you'll have X-plug leaking again.
True?
PS pump used in UrS cars has two sections, one
for brakes, one for PS.
True?
If twice true then which section of the pump
does X-plug belong to?
True?
True?
You said: (My comments are in CAPS - but I am not yelling):
changing Xplug o-ring stop leakage for some time but sooner or later you'll have X-plug leaking again.
True? COULD BE TRUE. THE X-PLUG O-RING SEEMS TO DETERIORATE OVER TIME. EXTRA PRESSURE FROM BLOWBY AROUND A PUMP PISTON COULD MAKE IT LEAK WORSE OR SOONER.
True?YES.
FIRST OF ALL, THERE ARE MORE THAN ONE X-PLUG ON THE PUMP. THE ONE WE TYPICALLY HAVE PROBLEMS IS THE ONE ON THE TOP. YOU SHOULD BE ABLE TO FIGURE OUT WHICH X-PLUG (LOCATION WHERE THE PISTON IS LOADED INTO THE PUMP DURING MANUFACTURE (AND REBUILDING) IS LOCATED BY FOLLOWING THE APPROPRIATE PS AND BRAKE BOOSTER HOSES BACK TO THE PUMP.
PERSONALLY, I WOULD THINK YOU SHOULD BE LOOKING FOR A NEW OR REBUILT PUMP IF YOU ARE HAVING THAT MANY PROBLEMS.
True?YES.
but someone told me that changing x-plug with its
oring is just short time cure due to that piston
wear and excessive pressure under the plug
soon I may be forced to take out generator
so rebuilding/exchanging PS pump at the same
would be easier task but for sure is a lot more
expensive and time consuming than just replacing
oring - hence my questions
I'll have PS pump which have PS section in a
very good condition so I'll try eventually
to rebiuld this one and then swap
thx
thx
<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/154636.phtml">O-ring and X-plug details in the FAQ</a></li></ul>
Turbo_Anarchy
Audi Original "S" Cars
03-05-2007 10:08 AM
dfinn
9
01-26-2006 10:40 AM
