zOMG! WE HAVE OIL PRESSURE!!
It was actually only 11:45pm. The old UrS can't automatically adjust for daylight savings.
<img src="http://pictureposter.audiworld.com/67654/cimg1625.jpg">
These were the key... socket head cap screws torqued up to 48 ft. lbs. as per the Bentley.
<img src="http://pictureposter.audiworld.com/67654/cimg1624.jpg">
I Plastigaged the radial clearance of the new bearing and got 0.051mm. According to the Bentley a new bearing should be between 0.018mm and 0.053mm. The wear limit is 0.160mm. Everything seems fine so far. I didn't put my subframe back in so I haven't taken her for a spin yet. She runs and revs fine so far.
How many miles ? What repacing the bearings help fix ?
What do you noticed afterwards in terms of improvements, revs quicker, smoothness ... afterwards
I'm asking cause I suspect my main crank bearings need replacing soon :-/
The remaining bolt broke and the bearing cap fell off causing low oil pressure. Thankfully the crank wasn't scored and I was able to slip in a new bearing and a couple new bolts. I doubt I will notice any different over the old bearing.
