How the Q4 e-tron handles regenerative braking
As an owner of a Quattro 55, I've been interested in learning how the Q4 etron differs in what options it has for regenerative braking. In looking at reviews, it seems like the Q4 has moved the "shift to S Mode" function from being a second tug back on the gear selector to being in a foot switch next to the accelerator pedal. Now, in the Q4: 1) if you pull back once on the shifter into D, the car acts like the quattro 55, where the car Coasts when no pedal is touched and all regen resides in the brake pedal (this is with the paddle shifter set in its Coast positon). In versions with the paddle shifters, you can select to move a portion of the regen to engage in the accelerator as you lift off the accelerator pedal. (It isn't clear to me as to how many paddle settings there are. In both cars the lowest setting is Coast. The Quattro 55 has two other settings in the paddles for about 25 and 50% regen transfer. The Q4 may have and additional setting?); 2) the BIG difference between the two cars is that in the Q4, when you do a second tug on the gear selector (which puts you into S on the Quattro 55) that puts the car into "BRAKE MODE". No longer can the car be made to Coast, but rather it basically moves the car into "One Pedal" driving mode, with really aggressive regen in the Accelerator pedal, which will itself slow the car quickly down to "creep" levels. I do not know if the Paddle Shifters work at all when you are in the "B" mode. Does this sound correct?
dave234 (09-04-2023)
Interested in the Q4 for my wife, and one thing I hate about the Tesla is the fact that you can no longer turn regen "off", for instance, for days where you are driving on super slippery/black ice filled roads. Regen is a nightmare in those situations.
Can you select to turn off regen on the Q4?
Havnap (03-11-2023)
I came across an interesting squib reading about the maintenance cost for the Model Y. Every two years a service, consisting of cleaning and lubrication, of the brake calipers is required for cars not in the sunbelt. Evidently, the one-pedal mode results in so much less exercising of the calipers that periodic maintenance is needed. The cost is comparable to that of an oil change. The lesson I take from this is that something less than "one-pedal-driving" might be a good idea.
1. B mode is a better way for the one that likes one-pedal driving. (I don't)
2. D-Mode dynamic lets you set a fixed regen level (0,1,2,3) and it will remember it even after hitting the accelerator
3. The blending is not as good as on the e-tron at low speeds. You feel the switching to physicals brake more.
Audi Q4 e-tron brakes & recuperation :: electrichasgoneaudi.net
How to use one-pedal driving on electric Audis :: electrichasgoneaudi.net
This article from the Audi Technology Portal explains how regenerative braking works on the Q4 and how it varies with both drive mode and gear.
https://www.audi-technology-portal.d...ectric-quattro.
In gear B (brake), the drive almost always recuperates when coasting but not when the car is at a standstill. The limit is hit at 0.15 g of deceleration. If “dynamic” mode is set in the optional Audi drive select dynamic handling system (standard in the Sportback), recuperation also takes place in gear D but at a slightly weaker rate than in B.
The optional shift paddles on the steering wheel enable the driver to select three different manual recuperation levels in position D – 0.06 g, 0.10 g, and 0.15 g.
My question… Is it really true that the highest paddle regen mode is no different than the shifter’s ‘B’ mode? That is, I cannot imagine Audi engineers creating for the driver 2 one-pedal driving modes that, in practice, offer no difference in behaviour(?) For example, say you’re in manual recuperation and paddle #2 regen mode (#3 being highest). What’s the difference now from going to paddle #3 or choosing ‘B’ mode?
I cannot imagine my question having gone not yet answered, but this thread comes close…
B mode I do not use, despite coming from a Tesla and enjoying one-pedal driving.
I think the difference for me is that the audi will not come to a complete stop and hold with B-mode, so it's basically pointless to me.
