Q4 Performance
Hi folks, I test drove the Q4 50 last year, but it was a rather brief drive. I was wondering if any owners out there have any insight on its overall performance, especially starting out from a complete stop as well as entering highways? I am assuming with the new 335hp motor, it should be fairly quick without hesitation.My current Q5e has the annoying habit of hesitating when starting off intermittently, which may be the result of the engine switching be EV and gas mode. Thinking about going with a Q4 next year when my lease expires.Thanks for the insight.
If you put it in Dynamic mode, the acceleration from a complete stop is pretty darn fast, perhaps not as quick as other EVs with 0-60 in the 4-second range but more than perfectly adequate. You should get the new 2024.5 Q4 e-tron 55 which not only gives you better acceleration, but also gives you 22 more miles of EPA range, all at the same MSRP. If I had known that the 55 model was coming out so soon, I would have extended my previous Audi lease by 3 months. I don't know if the lease terms would be the same, but I would get the 55 model for the better range alone.
EVs have great acceleration from 0-60 but power drops off significantly after reaching highway speeds as the rpms of the motor are not in an ideal range at that point. The Taycan/E-tron GT address this by adding a second gear to keep the electric motor in the power band at highway speeds but this also reduces efficiency.
Also, Porsche, Audi and VW do not believe in making maximum power available from a standing start so the power is eased in more gently which can add a small amount of time to the 0-60 number while maximizing comfort and reducing wear. They are all very fast or at least reasonably fast.
Personally, I’m still wanting to find rationale behind Audi not allowing to use the power “boost” unless the battery has a SoC of at least 88%…(?)
Peter S
A4 (B8 Platform) Discussion
03-06-2021 04:34 PM
