Anyone change their own oil in RS Q8?
Seems impossible to book a service, if anyone even answers the phone these days, that is.
I am at 10,500 miles on original oil on my 2021 RSQ8.
Tempted to just change it myself. Has anyone done it and, if so, easy peasy or advise against it?
This is more or less the same as in 3.0T engine. Remove the air filter housing to gett access to oil filter and drain the oil from the bottom with the plug of the oil pan.
You don't need such a sophisticated equipment like here.
The tightening torque of the oil filter housing is 30Nm. In addition to the oil and the oil filter with O-ring, you will need a new pan oil plug with a copper gasket.
SQ8westcoast (04-19-2022)
JOEMB239
https://www.youtube.com/watch?v=E18E08BNa90
https://www.youtube.com/watch?v=3zqFeo3rALI
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
joemb239 (04-20-2022)
Looks like he performs engine flush before changing oil. I have never done that. I don't know what is he using but is it good (advisable) to put some chemicals which could potentially damage seals in a new engine?
Flushing the engine will not damage the engine or any seals. But doing it in a new car doesn't make sense though. This is sometimes done in older high mileage engines to remove carbon deposits from the engine components and oil system. I don't know why this guy does it in a relatively new car - it won't hurt the engine, but it won't help either.
Janez (04-20-2022)
I got my first oil change at 10k. Did a second myself at 15k with a pump. Super easy. I think I removed just over 9 liters. Now at 20k and going to dealer for technically my 3rd oil change.
https://www.ecstuning.com/b-bav-auto.../b8800001~bav/
Is there an oil extraction plug near the oil filter, like the RS6 Avant has, or did you extract thru the oil filter reservoir? This will be my first attempt on the RS Q8, doing a 5k change in between scheduled 10k service. My Avant takes 20 minutes start to finish, this looks more involved so trying to educate myself prior to going in.
![](https://cimg6.ibsrv.net/gimg/www.audiworld.com-vbulletin/2000x1342/a5de7116_1197_4cf5_ae86_cb714331549a_1_201_a_a624101770971ea86fa0cef469c3c61a1ec9e679.jpeg)
You certainly can't hurt anything by having your oil EXTRA clean - however, I think there's a point where it's a diminishing return, but what that point is would be subjective. I can say I wouldn't do it once a week. My understanding w the upper end synthetics (like they use in these cars) is they can EASILY go 18,000 miles - even then you can just do a new filter and a top off and go another 10,000 miles. I think audi does new oil at 5k miles, then new oil every year, which is about 10k or 12k miles typically. Unless you were doing something unusual, the factory intervals should be more than adequate.
