Downpipes
#101
correct. Can’t stand the smell.
Yesterday I had two 8” cherry bombs welded in the upper exhaust where the 2 “empty cans” used to be. It sounds amazing now. Got rid of the rasp when shifting from 1-2 and 2-3.
The cat’s will quiet it down even more.
#102
Hey, I removed my airbox today and tried to remove the sensors from the downpipes, but they were stuck solid. How hard did you have to crank the wrench and in what direction? I tried and tried and couldn’t do it.
#103
It is possible that your sensors were mounted without mounting paste and the threads simply stuck. With the engine cold, try spraying it with penetrating oil and let it sit for a few hours.
1stRS (07-29-2022)
#104
Been over 110 miles and CEL is off. Seen like what I did is working
i got the new spacers that built in with Cat from Walmart. CEL on again for being too lean. So I removed the cat/filter that built into the spacers. Seem like is working
from my understanding sensor can’t be too far in DP or too far out.
#105
Good to know. Since I can’t get mine to let loose, and I’m worried about breaking something- I’m going to forgo the spacers.
Question- do your 200 cel cats still smell like fuel? My wife won’t drive in my car she says it smells so bad to her.
#106
damn that’s suck. Well. Mine does smell a bit but not as bad as cat-less. I know for sure cat-less it would be bad.
#107
A picture and Some sound with the no cats, straight pipes and 8” cherry bombs.
Pabla (08-02-2022)
#108
One more
Pabla (08-02-2022)
#109
What's the verdict?
I believe I have tried to read through all of the posts and see the overall history of your exhaust mods.
What was the final solution that you ended up with? Could you provide a detail list of what all you did? Did you end up going back to the OEM down pipes and keep the cherry bombs?
Also, where did you purchase the cherry bombs and did you put those on in place of resonators one and two? And then keep resonator as straight pipe?
thanks so much!!
RMcQ
07-04-2022 12:06 PM
Fixn2xlr8
32
08-04-2005 07:38 AM
davyk3
07-16-2005 10:47 AM
MarcDC
07-30-2002 12:14 PM
