iPhone overheating while Wireless Charging
Ive seen reports of this all over but never saw if there was a solution. If I put my phone on the wireless charging pad while using CarPlay it will overheat after a while. This doesn't happen when I use a wireless charger at home, so I think it's something in the Audi. Has anyone found a fix to this?
The following 5 users liked this post by Pandacansado:
Andrey Kashubsky (03-15-2021),
imdakine1 (02-03-2021),
jhirshberg1951 (06-20-2023),
SouthernGalTX (12-03-2023),
tommy.ym@gmail.com (05-21-2022)
I believe apple even warned about using specific wireless charges with their new iPhone 12 as well.
The following 2 users liked this post by beachbumjbs:
flowerbunny (06-29-2023),
jwizzle (04-03-2023)
There are a couple of issues I can think of for this matter. The wireless charging system in the car most likely to have heat traps since we are in the winter season, heat in the interior, heat in the vents under the almost useless space at the wireless charging station. It's even worse if you have a protection case for your phone. Aside from being charged wirelessly, your phone is being used (Apple Carplay) vs it's resting on the wireless charging station at home, this creates more heat. Someone corrects me if I am wrong. =)
The problem with wireless charging affects many cars. As you will look at the BMW X5 / X6 forum, users also complain about slow charging and overheating of phones. This is especially true for the iPhone.
In fact, in-car wireless charging can be used more to maintain the battery level than to charge it.
If you want to charge fast your phone in the car, use the cable.
