New RS Q8 - Anyone removed the rear large resonator?
#21
@1stRS did you only do the large resonator or have you taken out the two smaller ones up front as well? If so did it make an even bigger impact? Did it cause any drone on the highway at 90-100mph? Thank you!!
IF I was to do this all over again, I'd remove the larger resonator (in the middle) and leave everything else in place.
#22
First time posting. First time Audi RSQ8 MY23 owner. My question is about the 2 mandrel bent pipes that are installed where the large middle resonator is being removed. Did you take pipes with you to the exhaust muffler place in Denver which they then installed for you or did they have them in stock? This is my first deresonatoring project and I want to ensure I follow what you have done to a tee to not make mistakes. My local shop mechanic is also having a look around but I value your opinion here having read alot of forum posts of late.
#23
The reason I removed the entire exhaust system was that I didn't like how puffy it sounded (like a steam train). I saw that APR just came out with their exhaust for 4.0, very interesting. If I didn't already have straight pipes, I'd probably go that route.
#24
I had the local shop weld in custom bent pipe. There are aftermarket pipes that can be purchased and attached via clamp, but it was far cheaper to have the local shop do it.
https://youtu.be/N9eNsBVpVG0?feature=shared
#25
took my car into the shop today to remove the resonator. Was quote $170 to weld in new pipes. Got car on the lift and low and behold mine already has the factory delete
ecloumd (11-07-2023)
#27
#29
Removed mine today….i think it’s quieter?
So got the large resonator removed today. Am I just missing it or for reason is it quieter? I feel like there is less burbles when downshifting and overall presence is less. Anyone experiencing this?
#30
That's rather disappointing. I bought 200CEL downpipes and will install them this weekend and post pre/post videos
