When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Yes, you do have to remove the oil line. I have tried and there is no way of getting the housing off the filter. **** poor design if I say so. Good luck.
That's what I thought. Do you have the part number for the o-ring, by chance?
Ok, I called my dealer as well, they seemed to think i was crazy when I explained the lines but claim to have 2 o-rings set aside. i'm not 100% sure they got the correct ones, but once I get confirmation of the correct i'll share the numbers for those who may need.
That is also the part number my dealer came up with, but they are certainly NOT the right ones. Here is a picture of that (black) over the correct one, you can see the size is way smaller on the orange ring. I've still yet to get an answer from my dealer, I think they gave up on me.
well great. Lol. I bent the passenger side one out of the way enough to squeeze the housing top out. Seems like what the techs do as well.
How? I put so much pressure on both lines to spread them apart that I was for sure something was going to break. Well, if you were able to do it, then it's possible. I was not brave enough to put more pressure than I already put on those lines.
Ill just keep removing the line like I have.
Also do you have a picture of the oil line once you moved it out of the way. I want to see how far you had to go.
yep here you go. Also, are you replacing the o-ring every time you disconnect
Yes I am. I have only change it once at 1K when I did the oil change. Now I'm around 3.5k so when I get to 5K I'll try forcing the lines further apart and see.
it wouldn't take any fancy engineering degree to figure out that the new oil lines should have been designed to allow easy access to one of the most frequently serviced items on the motor.
