Audi Q8 Discussion forums for the Audi Q8 SUVs
Suspension fault service mode error
Old 05-31-2022, 06:56 AM
  #11
BRITinUS's Avatar
Originally Posted by theasphalt
OMG - Codes didn’t work, but I poked around in the basic settings under programming mode and it has the option “Switch to normal level control function.” I said “eff it,” and hit the slider. It Immediately set my suspension where I usually keep it, and cleared the error. I am so grateful for your help, man.
I feel your relief. Congratulations on getting it back to normal!
theasphalt (05-31-2022)
Old 05-31-2022, 01:37 PM
  #12
1stRS's Avatar
Right on. Saved yourself a costly and uncomfortable trip to the dealer.
Old 12-21-2022, 03:43 PM
  #13
nick2413's Avatar
Hi guys, I have the same problem as OP, I wish I hadn't even bothered and my RS6 is now stuck in Air Suspension Mode.
I tried:
Programming mode > basic settings > Switch to normal level control function
This didn't solved my error codes and somewhat of a "limp mode".
I also couldn't find:
"DELETE CALIBRATION FOR LEVEL CONTROL"
Is there any way you're aware of to get it back to normal/stock using OBDEleven?
Many thanks.
Old 12-21-2022, 04:31 PM
  #14
theasphalt's Avatar
I tried:
Many thanks.
Try active level control,” then “start up to normal level” or “start up to reference level.” You may need to be in program mode. That’s what fixed mine with this exact error. I have the notes on that above.
nick2413 (12-21-2022)
Old 12-21-2022, 04:32 PM
  #15
nick2413's Avatar
Thank you! I'll give a go. Cheers!
Old 12-21-2022, 05:04 PM
  #16
nick2413's Avatar
Thanks again for the help.
This didn't work for me, when I am in "programming" mode I get a red "Function Not Supported" error.
When I use "VW diagnostic" mode, I can get to the screen to Activate Level Control and swipe the activation, it thinks for a bit but the status goes back to "NOT ACTIVE". I was thinking maybe this is still activate, but then when trying to swipe startup in normal or reference level nothing happens and I have the fault lights and error message in the pic above.
Old 12-28-2022, 12:18 PM
  #17
1stRS's Avatar
You have an RS6.. Hmm, Is there a "SHOW MODE" APP for RS6 in OBD11? You could try that and see if it gets you out of whatever you got into.
ALSO, basic settings in 74 is where the Activate and Deactivate level control lives.. enter security code, go to basic settings and see if you can do either.
Otherwise, try again first entering the security code, then changing back and fourth between the service modes.
Old 12-28-2022, 12:20 PM
  #18
1stRS's Avatar
ALSO, basic settings in 74 is where the Activate and Deactivate level control lives.. Enter security code and see if you can do either - leaving the mode alone.
  #19
nick2413's Avatar
thanks for the help. Ended up going to the dealer, they were super nice about it and reset everything in about 30 mins. What I’ve learned is that if you’re not 100% sure what something does on obd11 do not activate it!
Old 03-16-2023, 01:34 PM
  #20
nsol's Avatar
Default Etron
will this same recepie work with Etron S 2021 aswell?
Did you backup OEM settings? If so, you should be able to revert back.
I didn’t read the post from 2014 you linked.
Are you still having issues, do you still need assistance? Try this and let me know what happens.
I came across this YouTube video, then checked my own coding via OBDApp and again via OBDeleven and have indeed confirmed that changing these values will indeed lower your car.
watch this video.
https://youtu.be/j1swKY_1UKg?t=146
Here are the steps for the Q8.
74 Chassis Control- Adaptation
Body height left front wheel house edge
--- subtract desired drop from existing value and place that number here.
Body height right front wheel house edge
--- same as above
Body height left rear wheel house edge
--- same as above
Body height right rear wheel house edge
--- same as above
BASIC-SETTINGS -
ACTIVATE LEVEL CONTROL
(may need to enter security code, OBDeleven should provide for you)
START UP TO REFERENCE LEVEL
Quick Reply: Suspension fault service mode error
