Audi R8 Discussion forum for the Audi R8 and its variants
R8's awd system: Torsen or Haldex type? Torque steer?
Old 02-22-2008, 01:55 PM
  #11
Fxhomie's Avatar
correct, no electronic intervention in the R8.
Old 02-22-2008, 03:18 PM
  #12
VerrÜckt's Avatar
Default It sounds like you've got that down.
As said, the R8 uses a purely mechanical fluid coupling which increases torque transfer directly proportionally to the speed delta between the front and rear axles.
It's a Lamborghini design that isn't shared with any other Audi vehicle.
Old 02-24-2008, 09:14 AM
  #13
JohnLZ7W's Avatar
Default Haldex is a wet clutch pack, not a viscous coupling.
Normally the clutches are disengaged but as oil pressure builds the clutches engage and torque is transferred from the input shaft to the output shaft. So what causes the oil pressure? Differences in speed between the input and output shafts drive the oil pump. The haldex is actually a mechanical coupling in this mode. There is also an auxiliary oil pump which can be activated by the ECU to build pressure.
A popular mod for haldex equipped cars is an upgraded controller which takes a more active interest in torque delivery. The common blue (race) controller starts that pump when you mash the gas so it becomes a proactive solution rather than reactive (waiting for wheel slip).
Old 02-24-2008, 03:42 PM
  #14
New Member
QuiksilvaVandy's Avatar
Default um, how can it be VC? ....
Viscous Coupling requires tire-treads to be the same circumference and width right?
Old 02-24-2008, 03:43 PM
  #15
New Member
Old 02-25-2008, 04:37 AM
  #16
VerrÜckt's Avatar
No it doesn't. Circumference is important, width is not.
BigRonsAudi
09-04-2003 06:58 PM
ravidrabbit
02-05-2003 06:31 PM
zapco98
9
08-30-2002 12:47 PM
tt225tw
Performance and Tuning
29
06-20-2001 07:30 AM
Quick Reply: R8's awd system: Torsen or Haldex type? Torque steer?
