1997 Audi A4 Delta Radio Wiring Diagram
Hi! I need help...
I am installing an Amp/subs and I have a factory head unit (Audi Delta) and I don't know which color wire is the remote wire to hook the amp up to.
Can someone help me with a wiring diagram that tells what color wires go to what?
<center><img src="http://pictureposter.audiworld.com/66252/a3blaupunktconcertdiag2.jpg"></center><p>at the rear amp, which is bolted to the left rear speaker. Just use a 12v testing screwdriver to determine which wire goes on/off with the HU.
Thanks so much! I saw that on the top of the HU but it was kind of confusing to transfer that image to the actual back of the radio. Do you know what color that specific wire is?
Hello, If you haven't solved your problem, the wire is typicaly a white wire. Also you can check in the tech articles as there as various instructions depending on bose or non bose system. Good luck
naiku
A4 (B7 Platform) Discussion
11-21-2010 03:51 AM
fourwheelslide
05-29-2005 08:33 AM
