2 x 4-channel amps, how to run 2 x 4-ohm dvc subs with this amp?
While I was doing some early morning laps at the local pool some low-life smashed the front window of the car and took my mobile phone, wallet and then into the boot and took my sub box and Alpine amplifier.
It was my fault for leaving the wallet and phone in the front console in full view.
I've managed to get some used gear until I can put together the budget to replace the stuff I lost. I've now got 2 x Coustic 481qe 4-ch amps and a sub box with 2 x 10" subs 4-ohm dvc.
I will use one amp to drive the front and rear speakers. I tested one of these amps (before I bought the Alpine amp that was stolen) with my front and rear speakers and it performed well.
How do I wire up the subs and the 2nd amp to run the dvc 4-ohm 10" subs? This amp is not 1-ohm stable so I can't run the subs in series with the amp briged. I'm stuck with the amp running at 4 Ohm Mono: 2 x 240 Watts.
So how should I wire the subs?
The amps specs are are follows:
- Rated Power @ 14.4 V (0.1 % THD) 4 Ohm Stereo: 4 x 60 Watts
- Rated Power @ 14.4 V (0.1 % THD) 2 Ohm Stereo: 4 x 120 Watts
- Rated Power @ 14.4 V (0.2 % THD) 4 Ohm Mono: 2 x 240 Watts
Thanks in advance.
Thanks in advance.
theshack
02-05-2005 02:55 PM
digitalskate
12-13-2002 01:25 AM
