98 A4 Subwoofer install
I'm thinking of putting a sub in a small sealed fiberglass box on the side of my A4 sedans trunk. I'm looking for subs that are ok with only 0.5 cu feet or so and found the Inifinity Kappa Perfect 10.1. Would this be good for this purpose? Also i need an amp to push it would 300-350W at 4ohms be fine? This wouldn't drain my batter i presume. Any help is appreciated.
combo for less money. Also, try building your own box. It will save you a ton of money and you can build it anyway you like. Use the crutchfield.com teaching page to help. I did and it only took me about 1 hour to build it. Most speaker companies offer sub specifications you can go from there. Go to a local shop and check the best set ups. Then use the net to find the best deals.
<center><img src="http://www.brrman.com/temp/subbox/finished/Picture008.jpg"></center><p>It was perfect size for me.I can no longer use it since I now have an avant. Car accidents suck.
Marshall Tucker
A6 (C7 Platform) Discussion
12-08-2012 04:22 PM
black quattro
02-25-2004 10:37 AM
Trimalchio
01-30-2001 06:43 AM
