A6 Bose sub(standard) woofer questions
AudiWorld Expert
I have seen the sub(standard) woofer in the back of my Bose equiped 2.7t. Typical Bose - afraid of a driver over 6"! In any case, I have read every post to no avail. 1) How hard is it to remove the unit. 2) Where is the amp and what are the specs if it is seperate. 3) Is the input to the sub at line level or not. 4) Is there a solution for using the existing space for a replacement sub, and then placing an amp somehwere else. 5) If not, can you get power and line out easily from the existing wiring to add some sort of sub to the trunk. 7) Has anyone added a sub in a box that did not take up a lot of room. I think that is enough for now!
Follow the link to Bose subs<ul><li><a href="https://www.audiworld.com/faq/electronics.html">This may be of soome help</a></li></ul>
Karush Avagyan
06-02-2017 04:11 AM
smokeyb111
11-13-2004 12:20 PM
Jonathan Ross
10
04-24-2004 12:10 AM
