AMI/MMI Versions and capabilities (Confused)
Newbee here so bare with me.
I just order my Q5 20T 2012 with No-Nav and been trying to figure out the capabilities of the AMI Interface specifically to use with an iPhone-4, but after reading bunch of posts I'm still very confused as I have conflicting info, can someone please clarify and correct.
So far what I can gather from posts :
* Older MMI = 2G, Newer 3G (not sure about differences)
* Bluetooth for calls OK with iPhone in either version
* 2G MMI could do A2DP but 3G can't?
* There is an official BT Box you can buy to do A2Dp with 3G MMI?(http://www.iamaudi.com/audi-music-in...etooth-adapter)
* iPhone can be used and controlled as iPod connected to AMI Cable but it will go to airplane mode and U can not use phone?
* there are two different versions of the AMI/iPod Cable (one for each version of the MMI)?
* You could MOD an AMI cable so iPhone will not go to airplane mode and you can listen to it but then MMI will not control it
So can anybody confirm or disproof these problems/features?
Is there a place where I can get a current MMI/AMI Manual to check out these and other features (like capabilities of the SD cards)
Sincerely Confused...
