Amp keeps shutting off...
It will power up but after a few min it will shut off. If I disconnect the interconnects it will stay powered up indefinitely so I'm guessing it is going into some sort of protection mode. I'm running the line level signal from my stock HU (Symphony II) using the Blau adapter re-pinned into the stock plug. I think I've heard that output of the line levels is on the order of 1.5-2 volts. I turned the gains down to 1/4 and it seemed to stay on longer but eventually still shut off before long. Any idea what the problem could be or how to trouble shoot it more? The amp worked fine in my last install off a Kenwood HU so my guess is that it has something to do with the stock HU output...maybe the common ground is a problem for my amp (PPI PC4100)?
John P...any insight on this one?
I just thought of the fact that the stock HU uses a common ground for the line-level outputs...think this could be the issue? Otherwise I think it has to be something with the output voltage/distortion from the HU tripping some sort of protection circuit in the amp. I have an email in to PPI tech support looking for specific amplifier issues.
Yep...the amp isn't even mounted yet...just sitting on the carpeted floor of the trunk...
I only replaced 2 pins for the front outputs and left the rears alone so I could keep the Bose amp and speakers for rear fill. The PPI service rep I've been emailing with said it very well could be the common ground that is the problem. I'm going to plug in a portable MP3 player in place of the HU and see if the amp still shuts down. Assuming this is the problem, can I avoid using the common ground from the HU?
HOLD ON . . . that's your problem (more) . . .
<center><img src="http://www.exelaris.com/ttaudio/concert_label_close.jpg"></center><p>You have to ground them! It's the "Com." pin in the line out plug area.
I did ground them...
I spliced the 2 ground wires from the 2 channels of the blau adapter into the common ground from the factory deck. So what I have now is the two rear channels of the factory Bose amp and the two front channels through the blau adapter all use the common ground. The Bose amp doesn't seem to have an issue with this as it still runs the rear speakers fine. I disconnected the interconnects from my amp and ran a portable MP3 player directly to the amp and the system played fine for 30+ min while I did some tuning. So apparently my PPI amp doesn't like the common ground. Is there some other way to ground the RCAs other than using the common ground from the factory deck?
Yeah...I did and all they said was that the common ground could very well be the problem...
I have a post on Sounddomain looking for other grounding options. I don't know if I can just ground the RCAs directly to the car chassis or not. I'd be really bummed if I can't use the stock HU because of a small detail like this.
slingblade
A4 (B7 Platform) Discussion
12-29-2005 09:03 PM
Spooling_A4
04-10-2003 07:52 AM
Audrenalin
02-03-2003 04:14 PM
