Antenna Help - 2002 A6Q Bose
I've been reading a lot through the forums, and can't really find the info I need. I have the factory Bose system with the in-dash changer. Something is wrong with the Diversity antenna - again. I had this same problem once before, and the dealer fixed it. The radio will scan forever FM or AM. I can manually tune to very strong signals (FM), and AM is almost non-existant. Since I would have to bring it in to have fixed again, I'd like to try a different way. Is there an adapter that would let me use an aftermarket antenna? I really want to fix this once and for all. Installing an amplified AM/FM antenna which could actually be serviced would be much better in the long run, I think. BTW - I have VAG comm to diagnose if that would help. Thanks in advance.
JTravinski
04-03-2002 10:21 AM
