Anyone provide a little troubleshooting help?
I have installed an MTX amp with a Boston Acoutsics sub an a pre-fab Boston enclosure. I tapped the remote signal off the rear amps and used a small high/low adapter. I have had alternator whines before and thats not quite what I have but there is a noise that I can't quite figure out. With the car on there is a low humm from the sub set-up. With rpm's there is no increase in noise level so its not and engine induced noise. Is it likely the high/low adapter? Or is it the amp turn-on from the stock rear amp?
TIA for your help.
TIA for your help.
I use a star grounding configuration....ALL power & front end grounds to a common point on the chassis.
You could also try a ground loop isolator (available from Radio Shack) on the signal lines that go to the sub amp.
Jeff Davison
Jeff Davison
HX_Guy
34
01-12-2004 04:49 PM
baldmike73
01-07-2004 02:24 AM
DeionDavid
05-08-2003 01:25 AM
Spooling_A4
04-21-2003 08:00 PM
Spooling_A4
04-20-2003 09:00 AM
