B6 A4 Sub Install on Bose System
I know that you guys are going to kill me for asking, I tried searching alot and just want a last opinion before doing it myself or getting someone to do it:
I have a 2005 USP B6 with Bose, I just got Infinity Basslink II and wanted to figure out best/easiest way to install.
Question is, do I need a high/low converter like some people say or can I do what this link says:
http://www.audiforums.com/m_318162/tm.htm
W/O the converter?
Is this the easiest way to get through the firewall, by going through ECU box?
Thanks in advance, I am wanting the Bose amp to still power all the other speakers and get the easiest, best sounding install for the new Sub.
W/O the converter?
though you don't need to remove the 5th bolt which is tricky and unnecessary, and you don't need to cut a notch as there's a perfectly good spare grommet on the rubber boot where all the other cables enter the box.
noise & alternator whine into the Bose amp powering the cabin speakers. I've done this on about 20 Audi's using Alpine V12 amps and never had an interference problem. The pre-out is distortion free, but quite weak for a pre-out, at about 1v.
and bypasses the plenum. It is down lower than the brake booster, I need to look at my B6 again to confirm, but it might be on the right side.
and used the high level inputs on my sub amp. The amp is a JL 250/1 which has a built-in line output converter. If your amp allows for a high level input, it will have an LOC built in. The overall sound with my set-up (JL 250/1 with JL 8w7 sub) was absolutely astounding. i couldn't believe how much my entire system had been transformed.<ul><li><a href="http://pictureposter.audiworld.com/561/dsc01518.jpg">a little eye candy to finish it all off as well......</a></li></ul>
S4Rules
01-10-2005 06:03 AM
White Wolf Zhang
09-03-2001 03:11 AM
