B7 sedan fiberglass enclosure
<center><img src="http://pictureposter.audiworld.com/107306/encl_behind_door_2.jpg"></center><p>Well, we now have a molded fiberglass sub enclosure which will bolt into place in B7 and B6 sedans. There is a gap between the enclosure baffle and the trim panel.
It uses the OEM bolt on top and two screws through the OEM bolt tabs on the bottom.
The woofer in the pic is a DLS Iridium 10. I put the enclosure at about 0.8 CF. I like the DLS MW110 in there also.
If your A4 lacks the door and has an indented pocket instead, this won't fit.
http://pictureposter.audiworld.com/107306/encl_in_place.jpg
http://pictureposter.audiworld.com/107306/encl_top_and_rear.jpg
work. Impressive. Easily the nicest work I've seen for this application.
Have you considered fixing that gap issue or can't you due to some interference? I was in there once, but I can't recall how it looks exactly.
Let me be one of your early customers that will happily brag about the product for you. =)
I was very glad to find out that the B6 and B7 were close enough to share the same tooling... I've had such poor access to either that this pic is in a B7 I rented from Hertz! (For $160!)
The color was going to be black, and probably will be in future. Due to the curve, we needed a stretchy material, and the darker grays we had with no nap were not stretchy at all.
