Blitzsafe adapter question...
I've seen them mentioned a few times in regard to getting line-level inputs to the Symphony head units... does anyone know any websites that describe how they work?
Does it, for example, interfere with the use of the CD changer? I assume so, but maybe they did something clever.
Working out how I want to wire up an XM radio...
the Blitz Adapter works without the CD changer, and "fools" the H/U into thinking there is a changer present, and opens up the input at the 'Mode' switch.
This unit.
<img src="http://mk1tt.montebellopark.com/images/adapter.jpg">
Blitz makes other adapters for other cars that describe what you want, but not for Audi's.
However, if you have the CD changer, you can add in a relay at the back of the H/U, cutting the line-level inputs from the CD changer into the H/U.
This provides you with an A/B line-level input to switch bet. the CD changer and an Aux. in, like a XM radio.
This input can be RCA's or mini-stereo, doesn't matter.
You need to have a CD in the changer to support the changers link to the H/U to open up the 'mode' switch.
Look at the link below.
I've done this on TT's, A4's and A6's.<ul><li><a href="http://home.attbi.com/~jbipes/ttr/auxin1.html">Aux Input to the OEM H/U with the CD Changer.</a></li></ul>
This unit.
that simulates the protocol of the CD changer.
Protocol is simply a chip that contains the specific frequency and signals of the CD Changer.
The micro-controller is an 8-bit device that contains the code.
The parts are cheap, but the devils in the details.
Someone either reverse-engineered the code, or paid Audi/Panasonic for the code.
a dual input unit that is to come out in January. This unit will alow CD Changer/XM input all to the factory head unit.
Rumor is that you will only need to hit the MODE button to toggle through the inputs.
