CD Changer not working
I have just installed a oem cd changer in my 2000 A6 (symphony/bose). The changer powers up, I can hear the disc loading mech, the head unit displays disc # and track info. My problem- No sound.
Any ideas? The indash cd works fine/radio works fine. I was told, after the fact, that the install procedure was to disconnect power to the hu (battery)/connect cd changer/reconnect battery. I did not do this, I simply plugged in the changer.
Okay, being new to this forum is there anyone who can verify if there is a vag setting that will enable sound from the cd changer to be played through the system? Or am I looking for another explanation? Thanks in advance
so that the HU resets and picks up the new peripheral. Make sure you have the 4 digit code for the radio though, otherwise it will lock you out.
Update: I disconnected the battery then reconnected the changer. Once again, the hu recognizes the changer, displays disc and track info, recognizes empty cd slots, but no sound. I have check the connector - ok. Thanks in advance for any info.
Any time you add a peripheral to a head unit, you have to reset it somehow. Generally, this is just done by disconnecting power for a few seconds. Also, check all your connections and make sure there are no serious kinks in the DIN cable (it happens sometimes, don't laugh!)
RS4saloondrivr
RS4 (B7 Platform) Discussion
13
07-02-2008 05:26 AM
dimer
08-29-2002 06:48 AM
