Center channel speaker
I have a Bose non-nav symphony II. I've added a nice sub to replace the Bose sub and I've set the fader almost full forward to get rid of the rear muddyness, but I've heard disconnecting the center channel speaker helps alot. How do I do this?
Thanks
Thanks
...sorry I don't have the pin info for center channel.
You could also probably pop the center dash speaker out and disconnect manually.
Good luck!
Good luck!
Thanks, I never thought of doing it there. It would probably be easier than pulling the headunit. I was thinking I would have to get at the speaker. I think I found a wiring diagram on this site somewhere. Although that harness scares me a little!
so is easily identified. Skinny cable coming off one left connector and one right, doubled up with the main front speaker wires.
Mr Dobey
06-27-2007 07:03 PM
Taam
04-29-2003 08:24 AM
PDXTTCQ
04-25-2002 10:58 AM
discobarbie
15
04-21-2002 06:48 PM
