electronic crossover vs. using the ones in the amp?
any benefit to external crossovers to divide the signal vs. just running a full signal to each amp and letting the amps crossover do the work?
simple system...4 channel amp running 2 sets of components and 1 mono sub amp.
Amps are of pretty good quality - jl audio 300/4 and mtx class d mono sub amp.
your jl amp has a great crossover network for your purpose i don't know the mtx but they are a quality company outboard xovers may add flexibility but anytime you add a component you increase the possibility of noise i would use them as a last resort
AudiWorld Uber User
they may have different octave slopes, and the controls are usually rather imprecise.
However, if your amp has a signal output from it's cross over, you should be just fine. That's the way mine is set up.
I run a Audiocontrol EQX (Equalizer and X-over)running into a 2 and 4 ch Fosgate Amps. The EQX allows me to adjust each frequency and match to the octaves for signals properly routing them to the appropriate source. It also allows the adjustment of Sub/Mid/Hi frequencies after the head unit so that I can keep basic settings on the EQX and give simple tuning between songs that have too much bass or too little bass at the head unit.
Hope this helps.
Hope this helps.
jjm82
09-24-2007 06:08 PM
theshack
02-05-2005 02:55 PM
darkstalker
06-04-2003 08:27 AM
j-po
11-16-2001 05:46 AM
