Factory Amplifier Info
Can anyone onhere tell me if my 2020 Audi A5 Premium Plus with the 10 Speaker sound system actually has a stand alone amp? Audi's multimedia website states this: Audi sound system with 10 speakers, 6-channel amplifier and 180 watts. I ordered a Nav-Tv Zen-V and was called by their tech today to make sure I didn't need any other modules based on my system to make it all work. I guess I need the MOST system activated if it doesn't have the fiber connected amp. Any help any of you can provide would be greatly appreciated.
I'm assuming the amp is located in the trunk behind one of the side panels. That's where it's usually located in most Audis. The tweeters and woofers in all four doors share a common amplifier channel and use a capacitor on the tweeter as a high pass filter. The two outer speakers in the dash are the tweeters paired with the woofers in the front doors, assuming that's the configuration used in your A5. The center speaker in the dash and the subwoofer have their own dedicated amplifier channels. Four woofer/tweeter pairs + center speaker + subwoofer = 10 speakers + 6 channels.
Correct. However, there is not an amplifier to be found in the rear quarter panel. To my understanding, a few things changed in the 2020 but I can not find any info on this for the Audi sound system amplifier placement or if it is even a stand alone and not part of the control module. Main thing I need to figure out is if this system has the MOST system active for fiber connection.
[QUOTE = MywhiteA5; 25630859] Correcto. Sin embargo, no hay ningún amplificador en el panel del cuarto trasero. Según tengo entendido, algunas cosas cambiaron en el 2020, pero no puedo encontrar ninguna información sobre esto para la ubicación del amplificador del sistema de sonido Audi o si es incluso independiente y no es parte del módulo de control. Lo principal que necesito averiguar es si este sistema tiene el sistema más activo para conexión de fibra. [/ Quote]
En mi coche pasa lo mismo A5 Black Line 40tdi 2020 con Audi Sound System
Rocky-in-Connecticut
Q5/SQ5 MKI (8R) Discussion
05-06-2008 04:15 AM
Bariukas
01-13-2003 06:56 PM
xixon
07-13-2002 07:35 PM
Flask
03-13-2001 08:07 AM
