help for 4 channel amp and dual voice coil sub question
1 amp is a eclipse 4 channel ,bridgeable 2-3-4
and 2 ohm stable
1 sub 12 inch mbquart dual voice coil
can i plug 2 channels of my amp on the same sub if i use the same input signal for both ?
if yes how sould i plug my sub
1- both channels + on one side of the sub and a a little wire to the other + of the sub and same for -
2- plug 1 channel on one side of the sub(+and-) and the other channel on the other side of the sub(+and-)
sorry im french , hope it's clear thanks
and 2 ohm stable
it's the model 36401 from last year it's the same of the ea3422 of this year .I will call my local shop it's easier for the schematic of the wiring
you run the two + wires of the sub together, then from there to the + of amp channel 1.
then the for the two - of the sub, run a wire to connect them and then go to - of amp channel 2.
so ull have 2 unused channels on a 4 channel amp
Bjw444
A4 (B9 Platform) Discussion
11-13-2017 08:15 AM
theshack
02-05-2005 02:55 PM
Lightweight-USPowah
07-20-2003 09:08 AM
SKareKrow
07-03-2002 10:57 PM
