Help! F*d up the rear speaker wiring
Merry Christmas everyone!
91 CQ, pulled out the side panels, disconnected the factory speakers/harness. Weird connectors, not anything like the skinny/fat slide on that the after-market 5.25" Pioneer speakers I got required, so I tried pulling what appeared to be the wires connecting to the speakers (plug with 2 connectors, not the one with 4-5 connectors (assuming that's the amplifier connector). That was a no-go, so the impatient pr*ck in me decided to snip the two wires and connect them directly to the speaker.
turned factory radio on, changed fade/balance to right-rear, and got nothing... reversed the two wires to the speaker posts, still nothing.
WTH am I doing wrong?!?
From your description it's impossible to say what you connected to but Bose speakers typically run at .5 Ohms which means an aftermarket speaker, which is typically 4 Ohms, is receiving 8 times less power than the Bose speakers.
OK, here's the connector for the right rear speaker - I cut off the two wires I thought were for the speakers, but guess not... or maybe not getting enough power to make sound.
Tested the speakers in the front speaker location, and they're working OK
'88WinterBeater
11-28-2006 09:26 PM
the reverend maynard
05-07-2002 04:56 PM
