High pitched whine from speakers
I'm experiencing a high pitched whine that increases in pitch with engine RPM. It stops when i turn off the head unit. I'm not sure if its a head unit issue or perhaps something with the system voltage regulation. I checked the fuse for the sub which had blown - I replaced it and checked the sub and amp which work fine on an alternate audio source but no response from the head unit. Any ideas?
99 A4 1.8TQTip
99 A4 1.8TQTip
I'd start by adding an addition earth lead to the chassis of the HU, short length straight to the bodywork.
If it's an aftermarket HU, then it depends whether it's a Bose system (whine from all speakers) or non Bose - whine from just the rears.
With the Bose system you're screwed. Non Bose, just rewire the rear speakers directly to the HU as the rear amp is not only feeble but also wired badly and this will pick up interference. Bose has a seperate amp driving all speakers and you can't easily by pass it as the speakers are 2 ohm and sound dreadful without the Bose amp.
tonyimp
08-06-2005 06:42 AM
Kirath ¾-B0§t0n
16
03-28-2002 01:32 PM
Crazy Silver
07-03-2001 10:36 AM
