I have a low repetitive thumping sound coming from my sub and it won't
quit unless I pull the fuse on the amp. I just had the sub replaced under warranty and now this. I have a 12" JL Audio W-0. It's a strange noise. It sounds like a pulsing thump. Any ideas what it could be and how to fix it.
is for it to receive current from the amp
try unplugging your rca cables if it is still happening then you have either a wiring problem or a bad amp. if when you remove rcas the sound stops then the problem is with the radio or the cables between them check there first
boston_A4_avant
06-15-2004 07:18 AM
Ray Khan
03-08-2003 04:39 AM
Ray Khan
19
09-07-2002 09:58 AM
