I know this question gets asked alot...but
Are there any converters I can use to switch my 99.5 BOSE head unit(A4)to connect one RCA patch cable? Basically, I am installing a two amp plus crossover system, and retaining my factory head unit/cd changer. Am I asking for hugh problems? Should I just fork over another $500+ for a new head unit? What do you think? Thanks.
RichD
RichD
AudiWorld Expert
<p>Mark P
--> --> --> <a href="http://drive.to/marksa4">Quattrobonium</a> <-- <-- <--
<a href="http://drive.to/marksa4"><img src="http://ctny.a4.org/mark/markplink.jpg" border=0></a>
AudiWorld Expert
<p>Mark P
The door structure has changed a bit. You will most
likely need to trim some metal to get the speakers
to fit. I brought mine to some good installers
and they trimmed some metal to get my 5.25"
BostonRally's to fit.
Good luck!
-Alex
Good luck!
-Alex
The holes match fine, but when you try to stick the door panel back on the door frame, it hits metal (this is without a speaker). However, according to AlexD, there is an easy fix.
adammorley
02-17-2002 10:50 PM
BrunoTT
11-26-2000 05:19 PM
