I stuck my ear up to my "tweeters" on my factory Bose system but nothing....more
This is the cheesy add-on Bose subwoofer and Pioneer jury-rigged CD changer I'm planning on dumping soon. Is there a reason there's a tweeter location but no tweeter there? I assume there will be enough space to put in a 1" component there from past posts but I'm just trying to find out why this "upgraded" stereo has no tweeter...?
Thanks to anyone who replies!!
Must sound really woolly, are you sure they're missing, might just be knackered. 1" component tweeters just slot right in.
the door panels what's behind there. I'll definitely put in 2 way components and I'm leaning towards 4" components to prevent the hassle of making rings and having fitment clearance problems arise. I will try to design some sort of sub for the rear wheelwell. How many cubic feet needed for a 8" or 10" speaker in an enclosure?
So that's 16"x9"x8" (406mm x 229mm x 203mm) sealed enclosure, obviously more for ported. If you go down the JL route, get the more expensive dual voice coil version as it can handle a lot more power and gives you the option of running it in 2 ch mode at 2 ohms. I use their 6.5" sub in a custom wheelarch enclosure for the A3/S3, and that's a very small 18mm MDF enclosure, probably about 3litres, and it really works well. I've made over twenty of these for various A3 owners and everyones blown away by them. You do need about 300wrms to drive them well.
wheelarch panels in the A6 Avant. My CD player is there now but maybe I'd move it over to the other side where the present Bose sub resides,this would open up more space. What I really want is just nice tight bass to fill out the spectrum, not a punk kid jukebox so hopefully I could do an 8" sub with between 2-300 watts in addition to my 160 watt a/d/s amp for my components. Sound reasonable? I think I did see your sub in a past post, remind me of where I can see it again, it will give me some good food for thought. I like the idea of the MDF, an easy material to work with (what is used inside for deadening?)
Thanks for your continued good advice!
<center><img src="http://pictureposter.audiworld.com/66252/sub_collage_mid.jpg"></center><p>I use a spray carpet adhesive to glue it in place.
Here's a pic of the A3 stup, but you should have more room in an A6. An 8" with a good powerful amp will sound sweet. I tried shoehorning an 8" JL into the A3 box but although it sounded slightly better it was really struggling with the tiny enclosure.
I'd like to have the existing panel work as a speaker grill so really I just need to figure out the largest enclosure I can make that would work with an 8" sub. Yours is nice, you did it from scratch I presume?
should be well within the space available in an A6. Calculating it is not that easy if it is going to sit over the wheelarch, with my A3 design I just made it as big as possible in the confines of the cubbyhole and it worked really well, more by luck than design.
which is plastic and houses a feeble paper cone unit with an amp the size of a matchbox.
You should be able to mount the sub facing inwards no problem, there just isn't enough depth on the A3.
fan4F1
17
02-04-2003 02:21 PM
DannyA4
04-11-2002 10:59 AM
Dynaudi
01-24-2001 10:52 AM
