Which JL 12W3 model do I need?
your choice depends on your amp.
If your amp is 1-Ohm stable (not too common), then you can go with the D2 and get a lot of power out of that amp! Make sure you give it a lot of air and thick power wire.
Most amps these days are 2-Ohm stable, so the D4 might work for ya.
etc., etc., etc.
etc., etc., etc.
If u are doing a single sub...id prob do a D2 that is the 2 ohm version. Also take into consideration which amp u are getting. Some give the max power at 4 ohms and some at 2 ohms.
AudiWorld Expert
which I believe is 2 ohm stable.
I should've guessed that with the DVC design...duh. Thanks for the confirmation.
I guess it depends if I want the amp to run with a 2 or 4 ohm load. What do you recommend I run the amp at? It's mounted right behind the driver side rear seat. I'm also running an 8 gauge power wire to it. I should've requested 4 gauge when I had the install done.
that's what I'd consider doing.
I tried a google search on your amp, and everywhere I looked said it was 4 x 50w at 4 Ohms. Do you have the owner's manual?
AudiWorld Expert
searching the internet to verify if it's 2ohm stable. I do have the manual (in the car and too lazy to look right now) but I know it is 50x4. I'm running it in 3 channel mode with the rear channels bridged to give me 200W rms. I've been running a 10W0 (4ohm load) for a few years now but I need more bass.
I was just concerned about driving the amp too hard but I've read countless times how well PPI amps handle.
Sinister A4
08-02-2004 04:05 PM
Kapoosh1
07-13-2004 01:15 PM
Crisqo09 T.O.
03-29-2003 11:14 PM
Jason in Vancouver
01-08-2003 01:49 PM
