Led back lights
Yes, assuming you meant back-up light. https://deautokey.com/
Pricey but lifetime guarantee.
Check them out. Many folks on this forum have used them without any Canbus error.
Our LEDs will be bright:
https://deautokey.com/product/audi-1...-rs3-many-more
The price really comes down to what is used. We recently had a customer say they bought an Amazon LED that looked identical to ours but it was not the same brightness or cleaner color temperature.
These reverse really create a lot more light for seeing when reversing in your camera and having others being able to see you too.
w:http://deAutoKey.com
-Error Free LEDs for your Audi (interior & exterior)
f: https://www.facebook.com/deAutoKey
i: http://instagram.com/deAutoLED
Typical LED bulb has very high DC resistance that would cause Canbus error.
Just got a pair of back-up LED bulbs from Amazon, very bright with 5W power.
I have not installed yet, likely it will cause Canbus error and I do not want to add external dummy load, as it wastes power and generate heat.
I am thinking to add small resistor ~ 8 ohms in series with thermistor. The canbus would see correct resistance before turned on power.
As power turn on, the thermistor will open so not much power dissipate on resistor.
We take the worry and guesswork out of it - our LEDs will be brighter than most reverse and no errors guaranteed.
MichaelTT
02-01-2001 04:26 AM
