Location of rear speaker amp on 1998 A6 2.4
Can anybody help me with the location of the amp for the rear speakers on this car please,I have looked in the archives and can' find any info.
The car has a sub woofer in the right rear boot area,behind a removable panel.
I have no output from sub or rear speakers the fronts are ok as the are fed directly from the head unit.
I have checked the rear speakers and these are not open circuit.
the sub has a 12 volt supply and a good earth, also a white wire is energised when the radio is turned on,the sub has a red 8 pin plug.
This is a standard system, not Bose.
Any help would be very much appreciated.
Thank You
Thank You
Which is why both have died together.
Check the voltage on the white remote on feed as have seen this drop to less than 10v in the past and this is not enough to turn the amp on.
Either that or the amp is blown.
kazino21
Audi A3 / S3 / RS 3
12-21-2002 09:44 AM
Stranger
03-20-2001 09:37 AM
