making a basic box with MDF, any tips?
AudiWorld Expert
need some guidance on stuff i need or where/how do i get them
screw or nails?
glue? type?
internal manget bracing fitment directions (building a box for adire brahma)
sealants?
what material to seal the front side
board cutting DIY table saw or store can do it
any sites i can look up?
screw or nails?
glue? type?
sealants?
3/4" mdf
screws
heavy duty wood glue or construction glue...i used heavy duty liquid nails.
the brahma is like 35-40 lbs right? i dont think you'll need magnet bracing, just some good wood bracing will do. if you want you can use dowels to make a brace
to seal the inside u can use wood glue also. i used something different than liquid nails. i used titebond II cuz it was easier to work with when sealing.
you can cut the boards yourself if you ahve the right tools. a store could do it fo ryou BUT i would draw the lines out and be VERY SPECIFIC as sometimes they are sloppy and make quick measurements and your final box will be off.
screws
HeartlessNomad12
Pacific Northwest Discussion
12-16-2008 09:28 AM
Dead
10
12-02-2001 12:48 PM
