MDF weight vs Plexiglass weight?
#11
Wall off the trunk/rear deck of your car, get a pair of beefy woofers, and give each woofer a bit of power (I would say 600+ watts per 12" minimum). Also get a good eq and a good subsonic filter.
I have a free air setup in my car... It's set it up so I could convert it to AP, but never did. Even though my baffle is almost all fiberglass, I'm not really sure it saved much weight compared to a small sealed 12". It plays deep but doesn't really crank considering how much power the woofers are getting. An AP setup would probably be even more inefficient.
#12
subs designed specifically for free air use where as any sub (especially those with a slightly larger VAS) can be successfully used in an AP format do. Also because a freeair setup provides virtually no acoustic suspension, a sub must rely on its own suspension to control its cone movement. Whereas an AP setup does provided acoustic suspension, more power can be safely applied to a subwoofer. Though AP formats have a lower output than a conventional box, this is negated by the fact that an AP setup is firing into the cabin of the car whereas a conventional box must fire through the rear seats and rear deck (assuming the rear deck has not been ported). As in all things, there is always a tradeoff somewhere for everything.
doonie
03-06-2007 05:03 PM
luetie13
08-23-2004 04:00 PM
I thought of an analogy for sprung vs unsprung weight.Imagine running w/weight attached to your feet
Audi Junkie
11-25-2002 09:20 AM
S4_4MY30'S
05-24-2002 12:08 PM
zapco98
03-19-2002 04:55 AM
2, acoustic, compared, difference, enclosure, fiberglass, glass, lightweight, mdf, no, plexi, plexiglass, regular, suspension, vrs, weight, wieght
