Need help installing eclipse 5425
I need some help installing an eclipse headunit in my 96 a4. I read through "replacing the delta cassette" and it's not nearly detailed enough to help me. I have purchase everything which he recomended(Scosche in-dash installation kit, scosche connector, and the scosche antenna adapter). I've successfully removed the delta cassette and connected the antenna adapter but after this I'm at a complete lost. The wires connected to the car don't match what i have been supplied with. One of the 2 wiring harnesses coming out of the a4 matches the pins to the scosche wiring harness I purchased but that doesn't even fit in correctly, I could probably force it in but will refrain from doing so untill i know it has to be done. I don't have the slightest clue as to what I am suppose to do with the other harness short of cutting it off and beging to strip and match wires. i'll try to post pictures later tonight to better describe my situation. I know this has been addressed before, but I cannot find anything which will walk me through this install.
<center><img src="http://img171.imageshack.us/img171/9981/fasdf9nr.jpg"></center><p>have to post these one at a time... the pictures aren't loading when i post multiple wiht the img src tag. on the left is the antenna adapter, middle is the wiring harness which came wiht the eclipse unit and the right is the scosche wiring harness.
<center><img src="http://img474.imageshack.us/img474/8779/asdf4if.jpg"></center><p>Here is all the wires which were connected to my delta cassette.
<center><img src="http://img500.imageshack.us/img500/7454/cimg00664no.jpg"></center><p>And here are the two head units(eclipse on top, delta bottom). I hope this is enough for someone to give me some insight into what needs to be done. If you have any questions, solutions, or any insight please get back to me!
quattrodieselmpg
08-21-2012 09:46 AM
groale
06-27-2002 09:42 PM
