Noob question, getting a headache searching the archives!
Can I install an aftermarket amp and sub in a 98 A4 w/Bose system? If not can I just add an aftermarket head unit with the amp and sub and not have to replace the speakers? Thanks for the help,
Jeff
Jeff
More details please
You can keep the stock HU, add an external amp and replace the speakers; that's easy. Bose or non-Bose, it doesn't matter. You probably *could* add an amp to the existing Bose system (speakers and all) and add a sub, but why would you want to? I don't think it wouldn't sound very good.
So what you are saying is..
if I am going to add an amp and sub, I might as well change out the speakers, too. Or is it recommended that you just change out everything? In your opinion what would you do?
You can
Its easy, just tap into the wiring harness in your trunk that plugs into the bose amp. Use a line lever converter, or an amp with line level inputs. Easy as Cherry Pie. And she's easy. That ho.
The headunit is reasonably capable, so just swapping out the amp & speakers
will sound pretty good. Dunno about just adding an amp and running the factory speakers. I wouldn't do it. AFAIK Bose speakers are paper pieces of crap just like non-Bose, so I doubt it will sound any better than it does now.
pyranha
06-12-2006 12:11 AM
hotani
03-17-2005 01:15 AM
can you gain anything by just adding an amp to the factory HU & speakers and is this a simple instal
Imola Ghost
04-04-2002 01:36 AM
