OEM XM installation
Hi All,
I just installed the OEM XM tuner into my '05 (B6) A4 3.0 Ultrasport.
For some reason The factory radio will not recognize that there is now a SAT tuner connected.
I installed the XM tuner into the OEM space, plugged in to the factory harnesses, etc etc.
What am I missing? Is there something that I need to do to make the Audi headunit pair with the Audi XM unit?
One note, If I hold the SAT button down while switching the radio power on, the dash display reads "LOADING".
Any ideas?
Thanks to all in advance!
Any ideas?
With VAG-COM select address 56 - function 07:
?xxxxx: Options
+1 - Satelite Radio (US)
+2 - Digital Radio (Europe)
Did you install an IceLink or similar? If you did, did you remove the 3 wires from the 20pin connector to install the IceLink?
?xxxxx: Options
Hi,
Thank you for your help.
No I did not install am Icelink.
I will try to get my hands on a VAG-COM. Am I correct in assuming that an Audi dealer would be able to do this for me?
Dr Zayas
A4 (B7 Platform) Discussion
17
10-18-2006 12:01 PM
A42k
08-10-2005 03:29 PM
