paging TeddyBGame: how do you get the phatbox to work with RNS-E for a B5 S4?
your name comes recommended.
any idea how to get the phatbox to work with an RNS-E for my S4? proxus and i worked on getting in a A6 unit into my S4, but would love to get the phatbox hooked up too.
any ideas? also can you answer some of these questions?<ul><li><a href="https://forums.audiworld.com/s4/msgs/2319231.phtml">https://forums.audiworld.com/s4/msgs/2319231.phtml</a></li></ul>
....not of the aftermarket rnse harnesses have a CDC ground wire for the Sym I conversions....so you have to add it yourself. This was the case with mine when I installed it back in October.
Luckily, the phatbox's outer metal shield can ground out against the metal bracket where the CDC was mounted.
See this thread on how to use the pbox with the RNS-E. The pbox is a bit harder to navigate with the RNS-E...so it takes a little bit of time to get used to it. A word of caution -- get acquainted while you are in your driveway...and not while you are driving. It is very easy to lose focus when you are driving.
<ul><li><a href="http://www.navplus.us/forum/viewtopic.php?p=9035#9035">http://www.navplus.us/forum/viewtopic.php?p=9035#9035</a</li></ul>
it works just fine! i guess everything is grounded okay. thank the lord!
your right its going to take some getting use to to navigate the playlists, etc!!
any idea on how to get the guidance vocie in all the speakers?
