Question for MMI Nav. plus owners about HD Radio
Hello, first post, I actually own a 2012 VW Touareg. Don't judge me! ![Wink](https://www.audiworld.com/forums/images/smilies/wink.gif)
2011 & 2012 Touaregs equipped with factory nav have the RNS-850 nav-radio system. I have discovered that multiple RNS-850s have a defective HD Radio tuner. They are unable to play HD Radio in stereo. They can only play it in mono, and then only the left-channel information is present. The right channel is completely missing.
I realize HD Radio has many "issues" but this one is very clearly a fault in the RNS-850: It cannot play HD Radio in stereo, period. It has nothing to do with weak signals or dropouts. You can be in a very strong signal area and the RNS-850 will not play HD Radio in stereo. It plays regular analog FM in stereo just fine.
So in researching the issue I discovered that the Audi MMI Nav. plus system is essentially the same hardware as the VW RNS-850.
My question to Audi owners: Can anyone confirm that their MMI Nav plus system plays HD Radio in stereo?
You may ask: How do I tell? Well here's a Directory of HD Radio Stations (US). Try to find an HD Radio station as close to you as possible.
And here's a video I uploaded to YouTube that attempts to demonstrate the problem with the RNS-850 (best to use headphones if possible):
http://www.youtube.com/watch?v=rXq18aV-jSk
The video includes some general info on how to enable HD Radio in the Touareg and how it's supposed to work. Presumably the Audi system is very similar.
I would appreciate any feedback from my fellow VW Group owners. So far VW is denying that there is a problem and I'm trying to muster up as much corroborating evidence as possible. Thanks. Hopefully the Audi does *not* have this problem, but either way, it would be useful to know because if the Audi radio works correctly and it's the same hardware as the VW radio, then the VW should work too.
AudiWorld Expert
I do not have a problem with my car with HD radio being in mono.
I do have a issue with high frequency static (painful) when the station is going behind a hill, multipaths, or on the fringe of reception.
AudiWorld Expert
AudiWorld Expert
If any 2011 or later Audi owners with MMI HD Radio have access to VAG-COM I'd be very interested in seeing the VCDS data. Should be Module 56 (at least it's 56 on a Touareg).
Here's mine (some unique identifying data obscured):
> > Address 56: Radio (R) Labels: Redir Fail!
> > Part No SW: 4G0 035 082 B HW: 4G0 035 082
> > Component: Radio U SIRIU H53 0076
> > Revision: AB001007 Serial number: 156JY0B75xxxxx
> > Coding: 020007020100000001
> > Shop #: WSC xxxxx xxx 00001
> > VCID: 1F4D56AF0Exxxxx
> > No fault code found.
Here's my best shot at demonstrating the problem with the VW RNS-850, which is supposedly the same unit as the Audi MMI 3G (+).
Please use headphones if possible, and read the description (direct link to the video is above the embedded video window).
http://www.youtube.com/watch?v=sDi0dUAwRWs
